Calling method SetObjectId of interface IAcadBaseObject failed
OceanaPolynom
OceanaPolynom
Hello
I want to pick a point on a drawing, and draw some text at that point.  The text is in a textbox on the form.  I get the error message
"Calling method SetObjectId of interface IAcadBaseObject failed"
Private Sub CommandButton1_Click()
    Dim textObj As AcadText
    Dim textString As String
    Dim insertionPoint(0 To 2) As Double
    Dim height As Double
    Dim returnPnt As Variant
    UserForm6.Hide
    textString = Trim(TextBox1)
    ' Return a point using a prompt
    returnPnt = ThisDrawing.Utility.GetPoint(, "Pick a point: ")
insertionPoint(0) = returnPnt(0): insertionPoint(1) = returnPnt(1): insertionPoint(2) = returnPnt(2) UserForm6.Show height = 0.3
'CODE FAILS HERE Set textObj = ThisDrawing.ModelSpace.AddText(textString,insertionPoint,height)
End Sub
Ed__Jobe
the var textstring is probably not set because you can't Trim a TextBox object. You need to supply the value of the TextBox.
Ed
How to post your code.
OceanaPolynom
Thank you very much. This solution solved the problem
I changed
TextString=Trim(TextBox1)
to
TextString=TextBox1
TextString=Trim(textString)
and it worked perfectly
Thanks again
John
Ed__Jobe
Glad it worked, but what I meant was
textString = Trim(TextBox1.Value)
Ed
