BOM
Dear All, I read a lot of past post about Mechanical BOM extraction and so on, but most of them are written in C# or VB.NET or are related to past product dated 2012,and older. I have Autocad Mechanical 2018, and I found a way to access to part reference object and related BOM typical of Mechanical version. But my issue is related how to insert a new part reference inside my modelspace and attach to a specific object or geometry trough VBA code. Here below I tried a simple code to retrive part reference properties:
Sub Bill()
'Managers to extract/parse AutoCAD drawing information
Dim symBB As McadSymbolBBMgr
Dim bomMGR As McadBOMMgr
Dim BOM As McadBOM
Dim bomITEM As McadBOMItem
Dim name As String
Dim BOMbit As String
Dim data As Variant
'Defines the bill of materials managers for extraction
Set symBB = ThisDrawing.Application.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
Set bomMGR = symBB.bomMGR
'Tests for BOM with the name "MAIN" in drawing, "MAIN" is default when no title border is selected
If bomMGR.BOMTableExists(ThisDrawing.ModelSpace) Then
Set BOM = bomMGR.GetBOMTable(ThisDrawing.ModelSpace, "MAIN")
Else
ThisDrawing.Utility.Prompt "No Usable Parts List"
End
For Each bomITEM In BOM.Items
data = bomITEM.data
For i = LBound(data) To UBound(data)
'data(i, 0) is the what the general name of column
'data(i, 1) is the value in the cell
If data(i, 0) = "MATERIAL" Then
data(i, 1) = "CHANGE THIS VALUE"
Next
Next
End Sub
Above code working fine, but it's retrive already defined part reference, but I'm not able to find a way to insert a new part reference in a specific point, and as second issue, I'm not able to find coordinates of part reference found. Is there somewhere documentation about BOM and VBA ? Thank you for help
