give function multiple outputs by using array.
stefanveurink68AXD
stefanveurink68AXD
So, i've got some pretty big code which has to be done all the time, so i wanted to make a function of it.
Now, I've learned how to create functions, but the problem is, the function definition looks like this:
Function middelpunttussendwarslijnen(nlba As AcadLWPolyline, dlba1, dlba2 As AcadLine, sn1, sn2 As Integer) As Variant
I want 3 outputs, for your information: the x & y value of a certain coordinate, and the nr. of the coordinate.
So, I was hoping, by using the positions (0, 1, 2) in the variant, 0 & 1 could be x & y, and 2 the nr.. But, when definining the 0,1,2, by
middelpunttussendwarslijnen(0) = nieuweindpunt(0)
middelpunttussendwarslijnen(1) = nieuweindpunt(1)
middelpunttussendwarslijnen(2) = sn1 + x - 2
it gives me a type mismatch.
It would be an really awful solution to just do all the code twice in 2 different functions, 1 for the coordinate and 1 for the nr., so i was hoping there exists a more elegant solution.
anybody got any ideas? thanks.
norman.yuan
The function should look like:
Dim returnValues(0 to 2) As Double ''You need to declare the array element's type
returnValues(0)=nieueindpunt(0)
returnValues(1)=nieueindpunt(1)
returnValues(2)=sn1 + x -2 '' the assigned Integer value will be converted to Double implicitly here
middelpunttussendwarslijnen = returnValues
End Function
HTH
Norman Yuan
Drive CAD With Code
stefanveurink68AXD
genius! thanks a lot!
