bit math
bit math
bit math
I'd like to use bit codes in a similar way that object snap does (OSMODE variable).  For example 0 NONe , 1 ENDpoint , 2 MIDpoint ,4 CENter ,8 NODe ,16 QUAdrant ,32 INTersection et cetera
I'm not sure how to do the math though to figure out what for example 33 means.  I can see that 33 in binary 00100001 would mean EndPoint and Intersection.  Would you need to define Intersection = "00100000" , endpoint = "00000001", etc. and compare strings, or is there another much simpler method?
thanks!
http://www.cpearson.com/excel/BitsAndBytes.aspx seems to answer the question.
No I can't translate it 😉 but thanks
