need select path dialog userform
Okay,
I am trying to get a dialog box that i can select a path from. Im using it to make a script writer in vba. I have tried a few different ways. Ive tried using the "microsoft common dialog box" it says i dont have a license to do it.. or something... the other way is to add a reference through tools, and with like "textbox5.text" something that made no sense... does anyone have any idea of like a starting point on where to figure it out??? because im at a loss..
ps. sorry about the HORRIFIC gramer and spelling 🙂
hi try this maybe..
Function BrowseFolder(Optional Caption As String = "") As String
Dim BrowseInfo As BrowseInfo
Dim FolderName As String
Dim ID As Long
Dim Res As Long
With BrowseInfo
.hOwner = 0
.pidlRoot = 0
.pszDisplayName = String$(MAX_PATH, vbNullChar)
.lpszINSTRUCTIONS = Caption
.ulFlags = BIF_RETURNONLYFSDIRS
.lpfn = 0
End With
FolderName = String$(MAX_PATH, vbNullChar)
ID = SHBrowseForFolderA(BrowseInfo)
If ID Then
Res = SHGetPathFromIDListA(ID, FolderName)
If Res Then
BrowseFolder = Left$(FolderName, InStr(FolderName, _
vbNullChar) - 1)
End Function
Sub TEST()
'Dim fname As String
fName = BrowseFolder("Select A Folder")
If fName = "" Then
MsgBox "You didn't select a folder"
Else
MsgBox "You selected: " & fName
End Sub
Run "GetPasta" procedure.
'Declarações API
#If VBA7 And Win64 Then
    Private Type BROWSEINFO
        hOwner As LongPtr
        pidlRoot As LongPtr
        pszDisplayName As String
        lpszTitle As String
        ulFlags As Long
        lpfn As LongPtr
        lParam As LongPtr
        iImage As Long
    End Type
    Private Declare PtrSafe Function SHBrowseForFolder Lib "shell32.dll" Alias "SHBrowseForFolderA" _
        (lpBrowseInfo As BROWSEINFO) As LongPtr
    Private Declare PtrSafe Function SHGetPathFromIDList Lib "shell32.dll" Alias "SHGetPathFromIDListA" _
        (ByVal pidl As LongPtr, ByVal pszPath As String) As Boolean
#Else
        hOwner As Long
        pidlRoot As Long
        lpszTitle As String
        ulFlags As Long
        lpfn As Long
        lParam As Long
        iImage As Long
    End Type
    Private Declare Function SHBrowseForFolder Lib "shell32.dll" Alias "SHBrowseForFolderA" _
    Private Declare Function SHGetPathFromIDList Lib "shell32.dll" Alias "SHGetPathFromIDListA" _
        (ByVal pidl As Long, ByVal pszPath As String) As Boolean
#End If
Private Const BIF_RETURNONLYFSDIRS = &H1
Sub GetPasta()
    Dim bnfo As BROWSEINFO
    Dim sCaminho As String
    Dim lÍndice As Long
    Dim vJanela As Variant
    Dim iPosição As Integer
    Dim sPasta As String
    'vJanela foi declarada como Variant porque ela é do tipo
    'Long se o Office for 2007, e LongPtr se o Office for 2010.
    'A pasta raiz é o Desktop:
    bnfo.pidlRoot = 0&
    'Título
    bnfo.lpszTitle = "Selecione uma Pasta:"
    'Tipo de dado retornado:
    bnfo.ulFlags = &H1
    'Mostra a janela:
    vJanela = SHBrowseForFolder(bnfo)
    'Analisa e trata o resultado:
    sCaminho = Space(512)
    lÍndice = SHGetPathFromIDList(ByVal vJanela, ByVal sCaminho)
    If lÍndice Then
        iPosição = InStr(sCaminho, Chr(0))
        sPasta = Left(sCaminho, iPosição - 1)
        Debug.Print sPasta
    Else
        'Nenhuma Pasta foi selecionada
End Sub
