Automatically Run Program When Computer is Turned On
Message 1 of 14
I am wondering what is the easiest way to make a program
automatically run when the computer is turned on.
I have written a program that automatically does some
company specialized maintainance operations but it is
necessary that it should run automatically as soon as
user's machine is turned on.
In the good old days of DOS I think I read somewhere that
this is performed using somekind of batch file ... if I
remember correctly I think it was either Autoexec.bat or
Config.sys but I more inclined to think it might have been
Autoexec.bat.
But DOS has long been gone and all our machines are running
on Windows XP. Besides, I havent tried anything like it
even in the old DOS.
What files do I need to change in a Windows XP environment
how would the entry read... do I put it near the end, start
or middle?
Thanks for all the help you can give.
Thanks again,
Matt
P.S.
Incidentally, would it be possible by any chance to accomplish what I am trying to do without the need to alter any AutoExec.bat/Config.sys or equivalent?
Replies (13)
Message 2 of 14
Look into Windows startup/Shutdown script (in group policy editor).
If the computer is in domain network, domain grouip policy could be easily
used to control which computers runs which tasks at startup/shutdown.
You can also look into logon/logoff script, if the tasks to run is
user-specific.
If it is domain-wide settings, you need to go to domain Group policy Editor.
If it is non-domain computer, click "Start->Run->Enter "gpedit.msc"->Click
"OK"->Expense node "Computer Configuration->Windows Settings->Script
(Startup/Shutdown)"->double-click "Startup" or "Shutdown". Then add script
you want to use. Of course you need to prepare your script first (in
VBScript, PowerShell or any other Windows scripting technology).
wrote in message news:5749244@discussion.autodesk.com...
Autoexec.bat.
or middle?
Thanks again,
Matt
P.S.
equivalent?
Message 3 of 14
Thank you for your valuable response I will go and look deeper at the gpedit.msc command.
From the looks it then I guess Autoexec.bat is dead..
As you may have noticed I am quite new at it ... to become more confident I would really like to try maybe some simple task ... I would be trying to run an executable called OurSystemMaintain.exe ... I am wondering if you might know a website by any chance? Something with a bonus screenshot or two would be a tremendous boost indeed ...
Thanks again,
Matt
Message 4 of 14
I have tried the steps outlined currently but it keeps giving me the error saying "Windows cannot find gpedit.msc Make sure you typed the name correctly and then try again"
Wondering if there is another command that would perhaps say have a higher likelihood of being in the XP operating system. If none exists, wondering if there is a safe place (I do not use anti-virus and rely only on firewall) where I can download a copy of said gpedit.msc?
Thanks again,
Matt
Message 5 of 14
gpedit.msc is at "C:\Windows[or Winnt]\System32\"
I verified it with my WinXP, Win2003 and Win Vista.
"Norman Yuan" wrote in message
news:5749249@discussion.autodesk.com...
user-specific.
Autoexec.bat.
or middle?
Thanks again,
Matt
P.S.
equivalent?
Message 6 of 14
You probably have an Autoexec.bat file but just don't see it. By default,
"Hide protected operating system files" is turned on (in Folder Options |
View). To see it turn this off. Assuming you are talking about an .exe file, I
would think you could run it from the autoexec.bat file.
Another method would be to put a shortcut to your file in your Windows Startup
group. I do this to run another batch file with stuff that I did not want to
add to the autoexec.bat file.
(The above is for XP - I don't know if it holds true for Vista).
Ken Krupa
Message 7 of 14
Programs in Windows startup group is user specific, that is, only start when
a user is logged on.
"Ken Krupa" wrote in message
news:5749791@discussion.autodesk.com...
I
Startup
Ken Krupa
Message 8 of 14
Ed__Jobe
Matt, you didn't say if your program is a window's exe. If it is, you can just put a shortcut in the All Programs\Startup folder.
Ed
How to post your code.
Message 9 of 14
if you create a file called "AUTOEXEC.BAT" and place it in your root directory, windows will process it if found.
I use it, on XP SP2, to set a few paths on my system during startup. Message was edited by: DanLan
Message 10 of 14
Cannot succeed in finding that file for some reason .. what I am finding are these files glu32.dll gpkcsp.dll .... I do not know why but gpedit.msc would be in between those two files I tried to sort by name to make sure I am not missing anything and made sure the option to show hidden and system files are likewise turned ... unfortunately I havent any success in finding it.. it maybe probably in a majority of XP machines but it does not seem to be in all as my machine uses XP as well.
I havent checked with my other machine but I might have to look for another technique...
Thanks a bundle,
Matt
Message 11 of 14
Thanks Ken, yours and Ed's technique seem to be the way to go ... I tried it manually and it worked like a charm .
Thanks again ...
Gratefully,
Matt
Message 12 of 14
This is an interesting concept ... I will go and try it out as well ... thanks for sharing this strategy...
Thanks again,
Matt
Message 13 of 14
This method is straightforward and elegant .. I owe you and Ken ... I tried it and it worked like pure genius...
Matt
Message 14 of 14
Edit: Oops, please ignore, didn't read all posts throughly... Message was edited by: Colin French
