AutoCad VBA Region intersect (command IN "Intersect")
jalal.mousa
jalal.mousa
I am trying to write code subtract 2 region items
i found 1 way  using Autocad by
command Region and select 2 closed polyline
Then
command IN (intersect)  select 2 region objects ("RegionRoom") & ("RegionTile")
I search further and found that Boolean Method (ActiveX) may do the job
object.Boolean(Operation, Object)
AutoCAD 2022 Developer and ObjectARX Help | Boolean Method (ActiveX) | Autodesk
I created two Region object by using code to convert two closed polylines
the issue is that i am getting mistake when trying to intersect between two
any recommendations how to solve it
--Moderator edit: Put code into code window.
Dim MyApp As Object
Dim MyDWG As AcadDocument
Set MyApp = GetObject(, "Autocad.Application")
MyApp.Visible = True
Set MyDWG = MyApp.ActiveDocument
'GetEnt
Dim Tile As AcadLWPolyline
Dim Room As AcadLWPolyline
MyDWG.Utility.GetEntity Tile , pp, "Select a polyline: "
MyDWG.Utility.GetEntity Room, pp, "Select a polyline: "
Dim RegionRoom As Variant
Dim RegionTile As Variant
' set Region to match poly object
RegionRoom = MyDWG.ModelSpace.AddRegion(Room)
RegionTile = MyDWG.ModelSpace.AddRegion(Tile )
' in this part i am getting error result
Dim result As AcadRegion
Set result = RegionRoom(acSubtraction, RegionTile)
Ed__Jobe
You need to pay attention to the syntax that is used in the help document that you linked to.
First, you didn't even use the Boolean method. Second, the method doesn't return a result, so you can't use the Set statement. The method just alters the object that calls the Boolean method by adding or subtracting the object specified in the argument. So it should look like this.
RegionRoom.Boolean acSubtraction, RegionTile
Ed
How to post your code.
jalal.mousa
Thanks Ed
This is really very helpful
actually i tried first this way but for sure i did mistake with syntax i missed ".Boolean"
