Autocad 2025 - UPDATE - TABLE CELL VALUE
grobnik
grobnik
Hi to everybody,
I have a question about Autocad  VBA and Table writing value inside a cell. I recently made an update to 2025 version, but probably methods it was already available on previous release.
I never used before the second option below described.
I found on ActiveX on line Help two different methods to write a value into a Table cell's.
1)
object.SetValue nRow, nCol, nContent, acValue
2)
object.SetCellValueFromText row, col, val, nOption
 Apparently seems both methods has the same effect, but probably it's not true. Seems using the second one instead the first the Mtext formatting can be preserved by Option value setting.
In any case somebody could give me some further help on specific issue ? the best could be some real example.
Thank you
Ed__Jobe
Option 1 seems to be used for linked tables. See this NET wrapper function. It's confusing on what the difference is between Content and Value. If you look at the properties palette, only Contents is listed, not Value.
@ambrosl Can you shed some light on this? The documentation is not very clear.
Ed
How to post your code.
