auto plot 10 a3 to pdf
dasBootik
dasBootik
hi all i`m created code with vba to export 10 sheets from model to pdf`s but everytimes had error with line
result = ThisDrawing.Plot.PlotToFile(plotFileName)
can you help me to solve problem?
Sub PlotMultipleSheetsByPoints()
    Dim Layout As AcadLayout
    Dim pt1(0 To 1) As Double
    Dim pt2(0 To 1) As Double
    Dim plotFileName As String
    Dim i As Integer
    Dim OffsetX As Double
    Dim result As Boolean
    Set Layout = ThisDrawing.ActiveLayout
    Layout.RefreshPlotDeviceInfo
    Layout.ConfigName = "DWG to PDF.pc3"
    Layout.CanonicalMediaName = "ISO_full_bleed_A3_(420.00_x_297.00_MM)"
    Layout.CenterPlot = True
    Layout.PlotRotation = ac0degrees
    Layout.StandardScale = asScaleToFit
    Layout.StyleSheet = "acad.ctb"
    Layout.PlotType = acWindow
    ' based coords
    pt1(1) = 0#  ' Y1
    pt2(1) = 297#  ' Y2
    OffsetX = 420#  ' weigh sheets
    ' plot 10 sheets
    For i = 1 To 10
        plotFileName = "C:\Users\user\Desktop\autoPDF\" & i & ".pdf"
        ' offset for every sheets
        pt1(0) = (i - 1) * OffsetX  ' X1
        pt2(0) = pt1(0) + OffsetX + 50 ' X2
        ' set window to plot
        Layout.SetWindowToPlot pt1, pt2
        ' regen and plot
        ThisDrawing.Regen acAllViewports
    Next i
End Sub
Ed__Jobe
Have you stepped through the code to see if all the variables are being set as expected? Is the file path really "C:\Users\user\Desktop\autoPDF"? I assume the 'user' is properly set to your profile name?
Ed
How to post your code.
dasBootik
yeah, this pc have user name - user.
I changed this to
plotFileName = "D:\autopdf\" & i & ".pdf"
and this still don`t working. I also forgot to add scrin error
and after click debug
norman.yuan
Sorry accidently clicked "Accept Solution" button.
You may want to try to disable background plotting by setting "BackgroundPlot" system variable to 0 (and restore it back after your coded plotting.
Norman Yuan
Drive CAD With Code
