access the objects in the block definition object
jeremye86
Message 1 of 9
jeremye86
how can i access the objects in the block definition object?
I have a book that says
set objentity=blockobject.item(index)
or
set objentity=blockobject(index)
This does not work for me and the only way i could get it to work is to explode block as follows
blockObjects2 = objBlockRef.Explode
Set objentity= blockObjects2(0)
How can i do this without exploding the block?  I just want to access the first item, thus the 0 for index.
Replies (8)
Message 2 of 9
Ed__Jobe
Can you show all your code? What do you want to do? Are you trying to access the block definition or the reference?
Ed
How to post your code.
Message 3 of 9
jeremye86
        FilterData(0) = "INSERT"
        FilterType(0) = 0
        Set oSset = acadDoc.SelectionSets.Add("SS1")
        oSset.Select acSelectionSetAll, FilterType, FilterData
        rowperimsht = 1
        lngRow = 1
        For Each objInSelect In oSset
            On Error Resume Next
            effName = objInSelect.EffectiveName
            On Error GoTo 0
            If effName = "perimShtDyn" Then
                BlkAtts = objInSelect.GetAttributes
                PerimShtDimsArray(rowperimsht, 1) = BlkAtts(0).textString  ' pm name
                PerimShtDimsArray(rowperimsht, 2) = 1  'qty
                BlkAtts = objInSelect.GetDynamicBlockProperties
                PerimShtDimsArray(rowperimsht, 3) = Round(BlkAtts(0).Value, 3) 'radius
                PerimShtDimsArray(rowperimsht, 4) = Round(BlkAtts(2).Value, 3) 'left len
                PerimShtDimsArray(rowperimsht, 5) = Round(BlkAtts(4).Value, 3)  'right len
                PerimShtDimsArray(rowperimsht, 6) = Round(BlkAtts(6).Value, 3)  ' bottom len
                PerimShtDimsArray(rowperimsht, 7) = Round(BlkAtts(8).Value, 3)   'sht angle
                blockObjects2 = objInSelect.Explode
                PerimShtDimsArray(rowperimsht, 8) = blockObjects2(0).Area
                rowperimsht = rowperimsht + 1
            End If
            effName = ""
        Next objInSelect
I'm trying to get the area of the polyline in the block.  The code above gets the area correctly but i don't want to the block exploded.  I attached the block in reply.
Message 4 of 9
jeremye86
i believe i am accessing the reference
Message 5 of 9
norman.yuan
You do not need to explode to find entities in a block definition (AcadBlock). Simply loop through the block definition to identiy the entity in the block definition. In your case, Assume, the block definition has a closed LwPolyline, which you need to know its area. So the code would be like:
        FilterType(0) = 0
        rowperimsht = 1
        lngRow = 1
Dim area As Double
For Each objInSelect In oSset On Error Resume Next effName = objInSelect.EffectiveName On Error GoTo 0 If effName = "perimShtDyn" Then BlkAtts = objInSelect.GetAttributes PerimShtDimsArray(rowperimsht, 1) = BlkAtts(0).textString ' pm name PerimShtDimsArray(rowperimsht, 2) = 1 'qty BlkAtts = objInSelect.GetDynamicBlockProperties PerimShtDimsArray(rowperimsht, 3) = Round(BlkAtts(0).Value, 3) 'radius PerimShtDimsArray(rowperimsht, 4) = Round(BlkAtts(2).Value, 3) 'left len PerimShtDimsArray(rowperimsht, 5) = Round(BlkAtts(4).Value, 3) 'right len PerimShtDimsArray(rowperimsht, 6) = Round(BlkAtts(6).Value, 3) ' bottom len PerimShtDimsArray(rowperimsht, 7) = Round(BlkAtts(8).Value, 3) 'sht angle area = GetArea(objInSelect.Name) PerimShtDimsArray(rowperimsht, 8) = area rowperimsht = rowperimsht + 1 End If effName = "" Next objInSelect
Private Function GetArea(blkName As String) As Double
    Dim area As Double
    Dim blk As AcadBlock
    Dim ent As AcadEntity
    Dim poly As AcadLWPolyline
    Set blk=ThisDrawing.Blocks(blkName)
    For Each ent In blk
        If TypeOf ent Is AcadLWPolyline Then
            Set poly = ent
            area = poly.Area
            Exit For
        End If
    End If
    GetArea=area
End Function
HTH
Norman Yuan
Drive CAD With Code
Message 6 of 9
jeremye86
thanks for the help but not working as well
error 438 (object doesnt support this property or method) with this line
Message 7 of 9
norman.yuan
Well, not seeing all your code (and the drawing the code runs upon), I am not sure what is wrong. But to quickly prove my point, following code works perfectly with my AutoCAD 2018:
Option Explicit
Public Sub GetArea()
    Dim pt As Variant
    Dim blkRef As AcadBlockReference
    ThisDrawing.Utility.GetEntity ent, pt, vbCr & "Select a block:"
    If Not ent Is Nothing Then
        If TypeOf ent Is AcadBlockReference Then
            Set blkRef = ent
            GetBlockArea blkRef
        Else
            MsgBox "Selected entity is not a block!"
        End If
    End If
End Sub
Private Sub GetBlockArea(blkRef As AcadBlockReference)
    Dim blkName As String
    Dim area As Double
    blkName = blkRef.Name
    Set blk = ThisDrawing.Blocks(blkName)
    For Each ent In blk
            Set poly = ent
            If poly.Closed Then
                area = poly.area
                Exit For
            End If
        End If
    Next
    If area > 0# Then
        MsgBox "Block Name" & vbTab & blkRef.Name & "(" & blkRef.EffectiveName & ")" & vbCrLf & _
        "Block Area: " & vbTab & area
    Else
        MsgBox "cannot find closed polyline in the selected block """ & blkName & """!"
    End If
End Sub
The following video shows how the code works with 3 block references (of a dynamic block definition):
Norman Yuan
Drive CAD With Code
Message 8 of 9
jeremye86
thanks Norman, i was able to get your code to work.
I'm going to do a speed test to see if your code or
exploding a block reference to get  the objects that define it is faster.
I found that i can just delete the exploded objects after getting the properties.
Message 9 of 9
jeremye86
Norman,
I did a speed test and your method is almost 3 times faster Smiley Happy.  Also you helped me answer my original question.  Instead of looping through all object in the block definition i was able to get the first object by using 0 as index.
blkName = objInSelect.Name
Set blk = acadDoc.Blocks(blkName)
PerimShtDimsArray(rowperimsht, 8) = blk(0).area
