AcadBlockReference Rotation
i'm a newbie to autoCAD, and i'm trying to write a vb script to extract information from the CAD drawing. While testing, i found that for some drawing blocks, the corresponding AcadBlockReference Rotation returns 1.57, but when i look at the actual drawing, block properties, the rotation is 0. I'm not sure what's the difference between the two, can someone help? thanks a lot!!
dgorsman
Angle data is usually in radians, not degrees.
I know, but why one is 0, the other 90 degree (1.57)?
dgorsman
You will need to attach an example DWG file.  Otherwise, its just guesswork.
