Change all the attributes color
mohandis2
mohandis2
My drawing has blocks nested into blacks nested into blacks nested into blacks and so on, and every block may or may not have attributes, how can I change all the attributes color? Any help please?
truss_85
You mean inside the vba or outside ?
mohandis2
In vba,
truss_85
Here it is what you want:
Public Sub block_nest()
Dim objBlock As AcadBlockReference
Dim objBlock_objEnt As AcadBlockReference
Dim objBlk As AcadBlock
Dim objBlkRef As AcadBlockReference
Dim objEnt As AcadEntity
Dim var_atts As Variant
For Each objBlk In ThisDrawing.Blocks
    For Each objEnt In objBlk
        If TypeOf objEnt Is AcadBlockReference Then
            Set objBlock_objEnt = objEnt
            var_atts = objBlock_objEnt.GetAttributes
            For j = 0 To UBound(var_atts)
                var_atts(j).color = acRed
            Next
    Next
Next
End Sub
