View in Window
View in Window
Issue :
The "View in Window" dialog opens at the same location and size on the Primary monitor even after a move to a 2nd monitor and resize
The "View in Window" is accessed from
Project Explorer ->Preview tab,
Item General tab ( Associated Files )
Item View tab ( Attached Files & Preview )
Change Order Files Tab ( Attached Files & Preview )
Resolution :
Remember the location and size of the View Dialog.
5 Comments
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
bmatthews8LS6L
When one clicks on a preview and the View button becomes available, clicking on View opens a window that is always small and in the upper left area of the screen.
Please allow the setting for this default to be the last used configuration of TrueView.    I would like to see the default setting full screen or last used state.  The small window is often smaller than the Preview.
I do know that it only takes one click to expand to screen, but why not use that as the default.
Tags (2)
david_coulam
I would like to see this considered again.
bmatthews8LS6L
I agree.  Just add a pin/thumbtack to the window, so one can pin it where they what.   I really like the way the "Get" dialog box works with the pin in the lower right corner!
This method is especially helpful for those that don't use CAD, but need to view drawings from Vault.
