Vault SQL Distributor on a separate resource
Suggest that Autodesk start to support locating the SQL distribution agent on a seperate server to avoid overloading a Vault publisher SQL node.
SQL is very resource heavy and by splitting the publisher into sections such as a dual node SQL cluster, ADMS Server and a Distributer Server it would greatly improve throughput and performance.
Currently the distributer resides on the same servers as SQL itself.
For large replicated environments this would be a very positive move and bring Vault in line with other enterprise database systems.
Kevin.
Group Vault Manager, Subsea 7.
3 Comments
ihayesjr
Kevin,
Thank you for posting your idea.  Our team will review the idea for future releases and will update this request when it is decided.
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
