Vault should print drawings with the correct orientation
When printing a drawing from Vault, it should know to print it in landscape or portrait, depending on the documents layout.
5 Comments
ihayesjr
dvsmiller9
It should be able to check the orientation of each sheet.  I already do this through VBA to print to a custom PDF printer driver.  Should be a piece of cake for Autodesk to include orientation checking in the print engine of their base products.
Thanks for your comment dmiller. Our department is small and no one knows VBA. I am sure it would help with other tasks as well.
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
