Vault jobs produce non correct (non useable) files
It's nice that you can create Vault STEP files from Vault 2024 as standard.
However, if you work with model states within Inventor, the STEP files (DXF from sheet metal) created via the job cannot be used by the user because they are incorrect or not useable.
Currently, a STEP is only created from the "primary" model state (this also applies to DWF and DXF from sheet metal development and 3D PDF).
We are of the opinion that there needs to be a configuration switch that either excludes all models with a model state from generating Vault jobs with "neutral" data or a way to generate correct neutral data from all model states.
For a detailed description see Support CaseNo 20881042
3 Comments
DavidWarta
So an configuration option to say create .stp file for each model state with a certain naming convention vs only create .stp for primary model state. Sounds good.
Uwe_Lindner
Yes, correct, the file name of the STEP file can then be e.g. <filename>_<Name_Modelstate>.STEP
