Vault insert dwg with drag and drop, do not support XRef nor BOM info
  1. insert XRef via drag and drop
Autodesk comment from Case ID: 12271218
Drag and drop from VE only works if the files happen to already be in the local workspace. Also, it will not update the local files if they are out-of-date, which also means we won’t download the xref’s or repair references if needed.   This is a technical limitation to the way windows works. We have to pass the file path information at the start of the drag, and we don’t get a notification back when the drop happens.
sounds like a challenge for autodesk to make it possible
2. missing BOM Information
during the insert via drag and drop the Information from the BOM are lost
sounds more like a missing Feature, possible to put it in to the challenge
Kind regards and good luck for the developer
Jürgen
