Vault DataStandard for Vault: Support for creating multiple dropdown menus
I would like the support to be able of creating multiple dropdown menus in the Vault DataStandard for Vault (VDSV) UI.
Many thanks,
Kind regards,
Matthias Schindler
CAD/CAM/PDM technical specialist at
2 Comments
Markus.Koechl
Hi Matthias,
I am curious that we might overdo it in stretching the major purpose and benefit of VDS. Can you explain a use case and example of adding these subcommands (I am guessing that menu items should allow calling custom commands)?
Markus
mschindler-mum
Hi @Markus.Koechl,
in my use case I've nine different jobtypes:
  • released (PDF, DXF, STEP)
  • prototype (PDF, DXF, STEP)
  • draft (PDF, DXF, STEP)
So I need to define three dropdown menus so solve this today in the "Menudefinitions.xml" file.
Here is part of my "Menudefinitions.xml" file.
If I try to do this there with one dropdown menu item, and the others inside there, the item doesn't appear in the dropdown menu inside VDSV if click on a file -> right click.
That's just one an use case that I know so far, but I think there will be some more.
Many thanks,
Kind regards,
Matthias Schindler
