Vault Connector does not synchronise the BOM well with frame generator, tube and pipe and cable harnessing
In Fusion Manage, all lengths of cut material assigned to a single element lose their production information regarding the cut length.
AirSystemAssy.iam in Inventor
Inventor Main Assembly AirSystemAssy.iam with Tube & Pipe.
Inventor BOM with different Quantities:
-QTY (with pipe or tube part length)
-Item QTY (Quantity without length mostly each)
-Base Unit (with Each, in, mm)
Inventor Structured BOM:
AirSystemAssy.iam in Vault
Assembly File Structure in Vault with all Subassemblies and Parts:
Vault Item BOM:
-Quantity, Unit Qty, Units und Item Quantity
Fusion Manage BOM after synch with Vault Connector 2026.2
Fusion Manage AirSystemAssy BOM with tube & pipe parts:
Solution for the problem:
Why not design the Vault Connector so that it displays the instances as BG and the stock number (stock tube) with the length below it?
Once you switch to the Flat Bom, you'll even have the sum of the lengths.
1 Comment
georg_michalik
This is crucial for preventing costly mistakes during manufacturing and assembly. Thanks Adrian
