Vault add-in: remember comment when checking in folder
When checking in folders via the Vault Add-in available for e.g. AutoCAD, the previous folder path is remembered by default. However, the comment is not remembered, though I find it far more (or just as) likely that you would like to reuse the comment!
Thus I would suggest enhancing the feature by either simply remembering the comment, or adding a check-box where the user can decide his preferred behaviour.
1 Comment
mschindler-mum
Hi @jehd,
I think I understand your request.:)
As we configure comments for state changes for files, I think there would be a possibility to get it for other areas as you mentioned, in a future release,
Kind regards,
Matthias Schindler
CAD/CAM/PDM technical specialist at
