Dear Autodesk Technical Team,
I want to make a suggestion to you.
it is about Vault Numbering Scheme. The companys has created its own unique numbering scheme. They want to be able to use the listbox information used for numbering the design files in the drawings as well.
If the part number occurs in more than one listbox selection result. They want to use each selection value in drawings like the AutoCAD field property.
Customers want the numbering selection data to appear in file iproperties.
someone has already posted a similar thread on the forum
https://forums.autodesk.com/t5/vault-forum/separate-document-number-for-use-as-column-fields-in-the-...
Best Regards,
Hasan ER
