Upload File on State Change
Vault 2019 and above has the capability to sync to Fusion Team and BIM360. However, this syncing can only be done either manually, at a set time, or a set interval.
It would be great if we could trigger the upload of a file through Project Sync during lifecycle state change.
For example, if a file is transitioned from WIP state --> For External Review state, then that would also trigger an autodesk.vault.sync.manualupload job to the JobProcessor.
1 Comment
ihayesjr
Status changed to: Archived
Going to archive this request. You can set the minimum sync time to 1 hour. Instructions in your other Idea post.
