Update fields for DOCX / Office files with jobprocessor
I tried first time for mapping UDPs between DOCX and Vault. This seems rather slick and so far I'm very content.
One minor thing (which is more related to Word) is, that if you use fields/custom properties in Word documents as text fields, you have to manually update them to reflect changes.
So, Vault jobprocessor syncs all the properties like a charm. Interesting properties to map are for instance revision, state and latest approver.
If you use them in your document, you will notice that jobprocessor has updated the documents properties, but you have to manually trigger "update fields" in Word to make this become visible.
Wouldn't it be great, if the jobprocessor would run that command after it synchronized the properties? Simliar like drawings
  1. sync props
  2. update revision table -> update fields
