Thin Client Markup - Save to Vault
The markup save to vault is only available in the thick client, not the thin client. It would be extremly benefical if this was also available in the thin client.
7 Comments
ihayesjr
Status changed to: Archived
Thank you for posting the idea. As the Thin Client is meant to be only a Read-only client that doesn't require a license, it will not be able to save any data back into Vault.
smilinger
As I know, in the thin client we can update the visualization attachment of a file, isn't it already some type of saving-data-back-into-Vault? Unless submitting a job to the vault server does not require a license, because as far as I know this DO require a vault license. Is it some type of exception that you made specifically for this feature?
If you can make an exception for that then I strongly suggest that we also make an exception for saving markup in thin client either. Because I strongly agree with @graham.harrison7M6HM that it would be extremely beneficial if this was also available in the thin client.
ihayesjr
@smilinger
The Thin Client isn't performing the operation to create the visualization file. It is triggering it for the Job Queue so a Job Processor will pick it up, create the visualization file, and check it in.
ihayesjr
smilinger
@ihayesjr
I think triggering a job needs a vault license, at least from a vault API perspective, which kind of violates the assumption that thin client only need a read-only license that disallows saving data back into Vault. And technically it is saving data back into vault, as a result.
ihayesjr
e.hollestein
Since the Thin Client in 2027.1 can do multiple operations, like change state, for users with a Office/ Professional license + Autodesk Login. In the 2027.2 beta i see further expansion on this.
Is this back under consideration? Since multiple of our customers (we are an Autodesk reseller) would not mind to have Office licenses (named user or tokens) in order for people to make markup in the Thin Client.
