Thin Client 2014- Better Control Options
A site is preparing to roll out Vault 2014 with the usage of the Thin Client, however this site current does not use Item Masters. Their Question which became a great idea was:
The possibility to “deactivate” (hide on a global level) the “Item Master” buttons in the Thin Client regardless of what permissions are given to the user; which could then be “activated” at a later date when Item Masters are used.
This would could help for sites that do not use this option in vault and would reduce the questions from end users on why how and what.
8 Comments
ihayesjr
Status changed to: Accepted
ihayesjr
If you got this request, would it also involve disabling the Item master in the thick client also?
Good question,
As the Thin client users would not be using the Thick client, there would be no need to disable the item master.
YounesYammouri
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
ihayesjr
ihayesjr
