I'm releasing a drawing, that drawing has 100 uses parts/assemblies/drawings of said parts & assemblies.
20 of those files have property none-compliance flags. They're extremely difficult to find because they're nested down 10 levels into a complicated structure, and 'expand all' crashes the client because, because Vault. And I can't do sync properties on an entire structure because I don't know which property will be correct.
So I release the drawing, ERROR. But you only report one file as having an error, why?
I cancel the state change, go find the file, find out what the problem is, investigate what the solution should be, go back to the top level and go through the change state again.... ERROR. Now you show me the next file that has a problem.
I'm sorry, is this boring you? More than happy to swap jobs!
Please report on ALL files that have an issue when attempting to change state, please do not just report on one out of a potential many that have an issue.
