I have been using the Autoloader for Solidworks and found an unusual behavior. When in the 'Select Folder' screen, I want to remove several subfolders to reduce the folders being scanned and imported. If I sort the folders and then select a folder and remove it, the remaining folders go back to the original unsorted order as they were originally displayed when first loaded. I would like to see the sorted order persist, so that large lists of folders can remain in sorted order to better navigate those folders. This issue was discovered with the 2019 version of the utility, but we believed it was tested by support and seen in the current version.
