Select which Inventor session/window will open a Vault file
I was opening Inventor files from Vault with two Inventor instances running. The message we get is this (and the file will not open):
Since there is already a prompt in place, it would make it easier to have a selection of which window/instance of Inventor to open it with, instead of having to navigate our complex folder structure in "Open from Vault", or right-click and "Go to Working Folder", then locate the file among several within the folder and drag-and-drop it to the Inventor instance desired.
In some cases we need two different projects open to compare, and it is useful to have multiple Inventor sessions working in parallel.
Thank you.
5 Comments
gilsdorf_e
I think that running several Inventor sessions in parallel is not a good idea in general. The workspace architecture of Inventor does not support file versions. What result would you expect by opening assembly A containing version 1 of component B and in the other Inventor session opening assembly B containing version 2 of component B.
There can be only one version of a file in workspace currently.
Best regards
Erik
It is actually a great idea, but not in general. If you're not an advanced user, you might never open different projects. For advanced users though, this is extremely necessary at times. We generally open different files, but in the case you listed above, all it takes is a bit of common sense in saving a pack-and-go of the different version somewhere else. In fact, you would not be able to get 2 different versions overlapping the same file in your Vault workspace. And if you checked out (or removed read-only) from such file, you should overwrite the open version which would prompt Assembly A to be updated. For challenging projects we come up with bold approaches to work around them. I believe more functionality comes out of necessity, and peer pressure from the competition that might be able to do it. Thank you, - Gabriel
gilsdorf_e
Our users complain about this all the time, too. We have a high reuse of common components between projects. So people from the custom design department almost always want to open two projects in parallel. But I guess creating a pack& go would not be accepted by our users.
I'm more pointing towards Autodesk doing it like the competitors, for example naming the workspace file as "part.ipt.001" for version 1 or something similiar.
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
