Revit - Saving Families directly from a Project into Vault
Description
We require the ability to save a Family from a project (Project Browser) directly into Vault. Refer to the image below.
Impact
The current functionality is limiting the standard Revit workflow which users are accustomed to, and therefore creating more work for the user. Vault needs to be able to adapt to all Revit current workflows transparently.
Severity
High
Solution
Files should be able to be saved to Vault directly from Revit without the need to have to be saved to a local folder before being adding to Vault.
3 Comments
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
