Revit - Can't 'Insert Views from File'
Description
You cannot use the Revit 'Insert Views from File' tool with Vault. This tool is important for a AEC workflow in order to bring standard details into the project.
Impact
Standard details are an important part of an AEC workflow with Revit. Currently a workaround has to be performed to download the detail file locally and then use the tool.
Severity
Critical
Solution
Need better Revit integration with Vault. Many of the basic workflows for Revit are missing with Vault. In order for all the Revit content to be stored in Vault, we need to be able to have fluid workflows to interact with them between Revit and Vault.
3 Comments
ihayesjr
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
