Revise through user defined properties when loading legacy data
When importing legacy data in Vault using Vault Autoloader, there is no way to get a "predefined" revision using some specific properties.
What you have to do is: load through auto-loader, then search for the imported data, use the "Revise..." function, and select the new revision "From user defined properties".
However, when doing this, a new version is created for those files whose new revision was not the default one.
Now if you cannot release a file which contains a "newly revised" child, because in Vault this child's file revision used by the parent is not the latest. You first need to check out / open / save / check back in that parent file...
Here is an example: I have an IPT file, added through Autoloader, together with its parents (including drawings).
The IPT file had a value set in its iProperty "Revision" which was higher than the default rev. value for its category: after loading it, I used the "Revise" function to change its revision (from 01 to 02.a).
The drawing was loaded with the link to rev. 01 of the IPT file.
Revision change juste after Autoloader
Nothing has changed in the files.
I know want to release the part and its ascendants : I can't without updating the highest level file in Inventor, because of the revision change for the IPT.
File is not the latest
1 Comment
ihayesjr
Status changed to: Archived
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can base on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We are archiving this Idea because it has been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you are welcome to do so. We have found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
