If you manage several different Vault databases, it is far too easy to add an entry to wrong database, when checking in folders from e.g. AutoCAD. For instance, you are logged on to database A in Vault Professional and check out some dwg files. Then you process the files in AutoCAD and run the VLTIMPORT feature. Normally you are aware of which database you have logged on to in AutoCAD, but sometimes you are distracted and are accidenatlly logged on to database B. If you are lucky, you notice this misbehaviour more or less instantly and can correct your mistakes.
Would it be possible to add an option, that you have to specify which folders (and of course by default their subfolders) in "C:\Users\<username>\Documents\Vault" that should be possible to import from when logged on to a certain database?
