Hello, I would like you to release a proper API to be able to control the vault from Inventor in a decent way. I don't want to be offensive, but I find that using this code is really not very practical and professional. Especially since it is offered in the iLogic code examples:
ThisDoc.Save
Try
Dim oControlDef As Inventor.ControlDefinition
oControlDef = ThisApplication.CommandManager.ControlDefinitions.Item("VaultCheckinTop")
oControlDef.Execute2(True)
Catch ex As Exception
Logger.Error("Check-In failed; likely, the file wasn't checked out.")
End Try
This is the kind of feature I would like to have in the Vault API, along with thorough documentation if possible. Thank you:
Vault.archive(fullfilename,option..)
Vault.extract(fullFilename,option..)
Vault.get(fullfilenmae,option..)
Vault.undocheckout(fullfilenmae, option)
Vault.fileExist(fullfilename,option..)
Vault.getproperty(fullfilename,dictonary)
Vault.setproperty (…)
Vault.getCategory()
Vault.setCaterogy()
Vault.changeState()
Vault.getState()
Vault.changeRevision()
Vault.getRevision()
Vault.renamefile()
Vault.copyfile()
Vault.synchroniseProperty
Vault.createPDf (for job assistant)
Vault.createDXF (for job assistant)
Vautl.createSTP (for job assistant)
Vault.PropertyValue(fullfilename, “PropertyName”)
Vault.GetFileBySearchCriteria(…)
Vault.GetFilesBySearchCriteria(…)
Vault.GetFileByFullFilePath()
Vault.LoggedIn
Vault.Login
Vault.Logout
Vault.GetFileCopyBySourceFileNameAndAutoNumber()
Vault.GetFileCopyBySourceFileNameAndNewName()
Vault.MoveFile()
Vault.deleteFile()
