Project Sync manual sync
Project sync should have the option to perform a manual sync.  I want to only upload "Released" ".dwg" files to the cloud drive.  The only way to do this without manually waiting for a scheduled sync is to do a manual "Upload to Cloud Drive" on the dwg files.  However, if you do that it does not follow the project sync filters and uploads all of the .ipt, .iam, and .ipn files associated with those drawings.
3 Comments
josephcooley
I need it to be able to only sync the .dwg files and not the .iam and .ipt files because I'm sharing these with an outside vendor.  I only want to give them access to the drawing files so that they generate laser cutter code from them.  I dont want the .ipt and .iam files accessible.
YounesYammouri
@josephcooley quick question for you: if you are able to share the PDFs of the dwg with your outside vendor, will this help? Or they need the native dwg files?
Younes
josephcooley
@YounesYammouri  Unfortunately yes, they need to be dwg files because they can't use PDFs to program the laser cutter.
