Prevent mass download / limit number of files that can be downloaded in one time
Secure the Vault so nobody can 'Get' all the files in Vault over 1 time.
Current it is not possible to limit the number of files that can be downloaded from the Vault Server in one time.
7 Comments
ihayesjr
Thank you for posting the idea. Why do you want to limit the number of files that can be downloaded at one time? What problem are you trying to solve?
ihayesjr
Status changed to: Under Review
maarten.clerinx
There was an internal risk management meeting, where all the applications/services are analysed for mass download protection to avoid intellectual property 'mass download' by 1 attacker.
How can we avoid that an attacker is downloading the complete Vault with 1 GET?
RajSchmidt
You could at least prevent the download of the whole filestore. (Or tie it to certain rights/roles.) You already recognise that event since I get a warning message if I initiate a download while standing on the root folder ($).
As for other areas: I would not limit the actual number of files to download. What happens if the user runs into a really huge assembly?
Maybe it would make sense to introduce an additional right for downloading a whole folder? Sure, I can still go into it, select all and download. But it would increase the wall a bit.
Another thing could be to disable the download if there are multiple folders selected.
marina.collet
I would rather have a (built in) tool to analyse the files downloaded (who, what, when).
This tool could rise warnings if the number of files downloaded is above a certain limit.
If properly monitored, this should allow administrators to react quickly.
RajSchmidt
Hi Marina,
you already have that tool (kind of): https://knowledge.autodesk.com/support/vault-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
However, you should watch out for certain privacy issues of the users if you employ this. (At least that's the case here in Germany.)
Regards
ihayesjr
