predefine numbering Scheme for rename Wizzard
it would be great to have a preconfigured numbering scheme in the rename wizzward, like in copydesign.
In this case i would be able to set NumberSchemeCAD as the default when starting the rename wizzard.
Many Thanks
Daniel
3 Comments
ihayesjr
@d_stockinger
Thank you for posting the Idea but I am looking for a little clarification.
Once you set the default numbering scheme in the Numbering Schemes dialog. It is the scheme used in Rename by default.
d_stockinger
@ihayesjr
this is correct that the default number scheme is used.
In some cases you want to use the default numbering scheme.
In some other cases you want to filter out some numbering schemes, perhaps the default numbering scheme (if not set as default).
Sometimes users are using the wrong Scheme during the rename process, because they don`t have a quick access like copy design.
Daniel
ihayesjr
Now I understand. Thanks for the feedback.
