I'm posting a comment I had from an older idea discussion:
Now that I have used Vault Pro 2025 for a while, I find that the Go To command in the RMB menu is ok, but it could be better.
My process now is to :
- Set up the copy design
- Keep a copy of the source component open in Inventor on my left monitor
- Review the structure of the source component with Inventor and set each member file to copy in Vault, as required. I usually change out 10-50 components in a several hundred component assembly.
- Change all the part numbers using Numbering Schemes
- Whine that I can't change component iprops, like Description, during the copy design.
- Execute the copy.
- RMB on the top-level component and select Go To destination folder
- In the destination folder, RMB on the new top level component and select Get or Open
- Start updating the design as required.
I'd much rather have a Get or Open command so I can start work with Inventor as soon as the Copy-Design process is complete.
