Open from Vault dialog Checked-out File indication
When a file is checked-out by another user, the Vault Client shows a strike-through the filename.
However, the Open from Vault dialogs of both Inventor and AutoCAD don't show this strike-through. The only indication you have that the file is checked-out is because the Checked in field is empty.
It would be nice if the strike-through is also shown in the Open from Vault dialogs. Even further, if we could also show the Checked-out By not just as the username, but also by user attributes (i.e. as available in Vault 2022), maybe even an Avatar similar to what Fusion 360 Design Reservation does.
1 Comment
ihayesjr
@clastrilla You can add the Checked Out By column to the dialog to see the user's name.
