Multiline comment field within Vault
When checking in from Inventor the 'comments to include' dialogue is multiline, however only the first line is displayed in vault ( unless you mouse hover). Can additional lines be included in the vault grid view so it's clear additonal comments exist?
Andrew
15 Comments
Gene.R
I Agree
Word Wrap should be a toggle added to the customize view settings so you can turn it on or off when you need it!
for change orders, Items, and Files.
Gene
steveh5
We need it most in CO's!!!!!....I believe this might bea a SQL limitation, but just a guess on my part.
Was just about to create an idea asking to wrap the contents of the comments field to show more than one line but searched and found this idea ...
YounesYammouri
MTimmis_ADSK
I was looking to add an idea for wrapping in the comments, but this article has already beaten me to the punch. It would be great if Vault could Word Wrap the comment column, potentially other columns. Otherwise you get the following:
I would like to see this implemented to both the "Comment" and also the "Comments" fields.
My company is looking into using the "Comments" iProperites field to populate the revision description on the drawing which will also be visible in Vault in the Comments field.  Thank you
RobJordan
Hey all,
Some of our customers would like to see all comments wrapped at a glance on the History tab.
Currently if I wrote the following comments during check-in....
Vault explorer would show them like this...
It would be very useful for the comments to appear like this... (this would save having to hover over the comment for the full text to appear)
Something similar on the Thin Client would probably be helpful too. Smiley Happy
Hope you like this idea!
Tags (5)
Wil;l make traceability audits and progress review simple for a manager or for the QMS
Great Idea - Wrapping text for easier visibility of comments in the Vault system would be an asset to Vault Users and Managers.
DanSingleton
If I could upvote this 1000 times, I would.
DanSingleton
It's also pretty much the same idea as this one submitted in 2015, that has been "Under consideration" for over a year so vote for it too. https://forums.autodesk.com/t5/vault-ideas/multiline-comment-field-within-vault/idi-p/5575291
YounesYammouri
Status changed to: Accepted
Senthil_Kumar
We have implemented this in Vault 2020.1 Update.
Senthil_Kumar
Bambuch
With this new feature, the Copy (Ctrl+C) and Paste (Ctrl+V) functionality doesn't work on "improved" field (Comment) in any Tab (History, Uses, etc.)
It is realy helpful to Copy data from Vault grid to MS Excel or other app.
Please is it possible to make this field able to use Copy/Paste?
