Item ownership in replicated environments prevents re-use
We just implemented workgroup replication for our overseas subsidiaries. We have been using items in Vault form the start in 2012 and heavily rely on those for a lot of processes (Vault-ERP integration, manufacturing, quality documents linking etc.).
Our output usually is more than 200 items a day.
Now we start facing issues caused by the ownership design in replicated environments. One issue is, that if you update an item, the ownership of all child items is transferred to the workgroup that tries to update the parent item. This is a killer for re-use. Some of our bolts and nuts are used in thousands of designs. Their items are released and typically do not change a lot.
Even if a user is not even allowed to modify the items of these bolts and nuts, whenever a assembly is released which contains one of these items in the BOM, the item ownership will be transferred. That means ownership likely will be passed for these items all the time between the different workgroups.
I foresee that this will impact us a lot, because people will start seeing error 370 and 321 all the time.
My idea is:
If someone does not have priviledges to modify an item, leave the ownership where it is when updating parent items.
6 Comments
ihayesjr
ihayesjr
YounesYammouri
Status changed to: Accepted
Senthil_Kumar
We have implemented this in Vault 2020.1 Update.
gilsdorf_e
Okay, I just had the chance to test it. From a developer point of view, it's done.
From a users view, halfway done. For the linked files, the ownership is still transferred. 🙄
gilsdorf_e
All voters for this thread should also like this one here from @thomas_jamnik for a full solution
https://forums.autodesk.com/t5/vault-ideas/avoid-to-transfer-file-ownerhiop-of-an-iam-from-an-zstd-i...
