Inventor Project File should be managed current Vault Connection from VaultAddIn.
If you have any project file active and then log into Vault, VaultAddin should start and check if that project file belongs to the Vault connection. And if it doesn't, it will show a message with problems and then your selected project file, current Vault and Vault Server will be shown. The user should have the choice to change the Vault connection or automatically activate the valid project file. This should download the latest file version of the project file from Vault and activate it in Inventor. This should help establish a correct connection.
And if you manually change the project file or Vault Connection the check should run again. user should have the same options if Vault and Project File are not matching.
Vaults that don't enforce a project file via administrative Vault settings should also be supported. The following behavior should occur:
Show the user a list of all the project files that exist in that Vault. The user can just select a valid project file from the list. The project file will be downloaded and activated.
It would be nice if something like this were also available in the Inventor Vault add-in from Autodesk.
