Ignore Missing X-Ref and Reference files
We are on the cusp of installing Vault Pro to our company and the major hurdle for us is the inability to have Vault be flexible regarding reference files.  Isn't there a happy compromise here?  Our issue is we get data from clients that we do not own and cannot remove missing reference files in. We simply reference these files to our project data.  Vault will not let us bring these files in through the application interface and manage the reference files that are found on the main file because the children references are missing.  It seems that vault should handle this the same as AutoCAD.  If the file is missing, give me an option to resolve it or ignore it and move on.  For us this is a major hurdle and may actually prevent us from using Vault at all.  (sorry about the reference vs. X-ref terminology, I use them interchangeably due to also supporting microstation).
Doug Vincent
4 Comments
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
Dan_Margulius
Hi
We get files from a lot of sources, DWG with missing xref. it's common to find in a dwg a lot of
missing xrefs. We have the need to check them in but can't do that because of the missing files.
There is no need for Vault to check this, the engineers will fix the dwg later in the process or even not at all because they need the reminder that something was missing in the original package.
Also item creation in Vault is not based on this missing files so why enforce something that downstream does nothing?
Please vote to allow check in with missing Xref from Autocad.
Dan
Dan_Margulius
Hello
Is this idea dead in the water?
I think many people need this feature, it exist in other products and it makes sense to adopt business wise
from Autodesk side.
Dan
