Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Having an icon on every Inventor file that indicate that it have a drawing
Currently there is no immediate way to check if a file has an associated drawing.I have to open the "where used" tab and expand the tree to check if a file have an associated drawing or not.
It much easier if there is a column on the datagrid vie that indicate that a file have an associated drawing.
10 Comments
a.chinellato
Great Idea, it's a good solution.
albertuan
Good idea but how to implement it ? the icon has to apear when :
  1. There is a drawing in Vault vith a view referencing the model (like in where used)
    In this case there is a limitation: how to manage not "inventror drawings" ... even if scanned PDF or DWG made from scratch in ACAD ?
  2. When there is a file name with the same file name
    Like now for DWF view file    šŸ˜•
  3. When there is a file with the same "part number" in the "drawing" (configurable) category ?
    (for now this is my favourite !)
omar_semenzato
For me it's very helpful too.
dsbogan90
I've actually often wondered how Inventor's 'Open Drawing' command, from a part, works when multiple drawings are available for the part... I only mention this because it opens the question how will it know if you have multiple drawing for the same part.. would it include "Multi-sheet" drawings as well or would there be a way to adjust it to show a "locked" assembly as apposed to an unlocked. We use the Locking of files as a way to show a files been released and now must go through a long change order process to alter but say someone just create a drawing to show the part as an idea and checks it in. then The Released file would technically have an idw but does not have a release drawing so being able to actually decipher the difference between the life cycle of the drawing would be helpful.
ivan_gani
On the "USES" tab, please add the possibility even to show the "included related documentation" (like, for example, during the change state).
j_weber
 Would it be nice to have a own column the shows that a part or and assembly have a drawing, like the column for the items. With this you can faster see that a drawing exist.
j_weber
Oh, sorry, I didn't find it.
YounesYammouri
Status changed to: Accepted
YounesYammouri
This has been implemented and available now within Autodesk Vault 2020. Please check the help for more details: http://help.autodesk.com/view/VAULT/2020/ENU/
j_weber
Great when it is implemented.
Haven't 2020 yet but looking forward to install
