Get in a flat list
Get in a flat list
If I do a get on several files in the vault to a specific local folder (ex. 2022_07_26_QUOTE_PROJECTNRxxxx), I should be able to find and the files in 1 folder with a flat structure.
Would it be possible to add the option to shoose "Vault folder structure" or "flat structure"
9 Comments
ihayesjr
@johan.degreef
Thank you for posting the idea. What problem are you trying to solve by changing the folder structure to a flat list?
Opening the assembly in Inventor will cause it to have to find all of the related files in the same folder, modifying the assembly.
johan.degreef
I tend to get all (pdf & step) files to a local folder for quoting purposes. It would be easy if they appear without Vault folder structure to allow easy selecting in an email.
ihayesjr
@johan.degreef
You can do this using Pack n Go.
ihayesjr
Status changed to: Archived
johan.degreef
I don't think so, I want selected PDF and steps to a local folder.
ihayesjr
See the image below. All of my PDFs are in different paths. Change the Output Structure to Copy to Single Path.
johan.degreef
I do not need ALL pdf and steps, but only selected.
ihayesjr
@johan.degreef
If you can find them in a search, you can select the files you want in the Pack and Go.
johan.degreef
I'll give it a try.
