Currently in Autodesk Forge, when a component is selected from the model panel, it enters automatically in an isolated view. This causes other components to become transparent. In the parameters, we managed to show other components but in a “semi-transparent” view:
Most of the time with big assembly more than 500 components, it is easier to find the part name in the model panel, select the part to view in the graphic zone (to review how the component is assembled or positioned for example).
Is it possible to have the same viewing mechanisme as in Design Review because the isolation mode in Autodesk Forge is extremely uncomfortable, especially those with colour-blind problems (Daltonian).
For example when a component is selected in the model panel in Design Review, the component is highlighted with another color instead of entering the isolated view.
The current Autodesk Forge parameters are extremely limited and it would be great to retrieve the same fonction as Design Review for Vault Client and Vault Thin Client.
