Folder Structures/Templates
Would be great to be able to (within vault not from explorer or desktop) create a template for job/project folders, this template/folder structure could then easily be copied for each new job.
6 Comments
khoskins
This is possible to do if you are using Vault Data Standard.  Or do you mean to have this natively built into Vault and not via another Add On?
tmuel
I agree this is a good request to have build into Vault, without having to set anything up using data standard. The workaround I have been using is this add-in.
https://apps.autodesk.com/VLTC/en/Detail/Index?id=847384442181865130&appLang=en&os=Win32_64
It works well, simple and effective.
Tim
YounesYammouri
NuPiFolder hasn't been updated in a few years.  It'd be great to have this integrated into Vault.  I have a folder structure template that has several empty folders to begin with (we use Vault to also upload Office documents that would be put in those).  This structure won't build with Copy Design and NuPiFolder was my only recourse.
j.vanovertveldt
I don't understand why it doesn't has this functionality within the Vault application.  To me this is essential!
Can someone explain me why?  I'dd like to know the phylosopy behind this.
ihayesjr
This has been implemented in Vault 2024.
