Fix illegible text for checked out files when using dark theme.
When using dark theme in vault, the text color for checked out files is dark blue on a dark background. These colors contrast poorly resulting in text that is very hard to read (and sometimes impossible on monitors with poor colors).
Text is barely legible when file is checked out and dark theme is enabled:
There is a work around to fix this however it requires users to go into the program files, edit a config file, and change a string containing an 8-digit hex code corresponding to the desired color. The larger barrier, however, is that this requires local admin privileges meaning a large percentage of users will effectively be unable to use dark theme (or will have to deal with some text not being legible).
Text color after editing config file (color value #FF32CD32):
I know many users have wanted Vault dark theme for a while and I'm very appreciated of the effort Autodesk took to implement it. However, with such poor legibility I fear that it is simply unusable for many users. Meaning all the effort spent to add dark mode is wasted for such a minor detail!
The best solution would be to allow users to choose the text color via a setting within the Vault Client. However, at a minimum, making the default color contrast with the background better will at least make dark theme useable.
This is based on a form thread I made here: https://forums.autodesk.com/t5/vault-forum/dark-mode-text-color-hard-to-read-vault-basic/m-p/1180257...
11 Comments
t_behrendH7AGP
Community Visitor
We also have encountered this problem today after updating a testclient.
Old Clients with a lighter blue color are Build 28.1.127.0 / 2023.1.1
New Client with the unreadable color is Build 28.3.21.0 / 2023.3
We can´t rollout 140 Clients with that, most of them are using Darkmode. It would at least help, when an update changes the color back to the light blue color (#FF3AABDF) for now.
was just about to post this same topic. glad you posted.
WG1987
Typical Autodesk as of the 2000's.  It will probably take 10 years to fix it.
gerald_chin
Hi all,
The above-mentioned user interface bug has been rectified from Vault 2024 onwards.
Cheers!
ihayesjr
fantastic
marina.collet
Well, it appears that this has not been implemented in all windows...?
ihayesjr
@marina.collet
Can you tell me which windows are not working?
marina.collet
@ihayesjr
After I changed the Connectivity.VaultPro.exe.config file to have a golden bold text for files checked out tom me, I see different colors in various windows:
- Get (remains light blue),
- Change state & change revision (are dark blue)
- Change category (bright red, not bold)
NB: I'm in Version 2024.4 (29.4.31.0)
marina.collet
@ihayesjr
Any news about this?
ihayesjr
We have not addressed those dialogs at this time.
