Show only
Search instead for
das könnte man relativ leicht über iLogic (relativ einfach, gilt aber nur für Teile, die die Regel beinhalten) oder über ein Inventor Addon lösen (gilt dann auch für Altdaten).
Speicher-Event abfangen -> BOMStructure Eigenschaft aus ComponentDefinition lesen -> Wenn gleich kPhantomBOMStructure, dann ein "true" in benutzerdefinierte Eigenschaft schreiben (Beispiel "IsPhantom" = true).
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes.
We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know.
- Vault product team
