Extended drug'n'drop
Enable ability to drag'n'drop properties in Vault Explorer from properties sidebar - that lists all properties of selected object - to add columns in main list instead using:
"Customize view" -> "Fields..." -> select object type -> select fields -> arrange fields -> "Ok" -> "Close".
It's faster and you always can see sample property value.
3 Comments
ihayesjr
Status changed to: Accepted
Hi MiWaNiZa, Thanks for taking the time to submit this idea. We would like to see what the community of users think about this idea.
Senthil_Kumar
Thanks for sharing your Idea. We use this forum to guide product development and help users in the best way we can based on voting. We occasionally merge Ideas or archive old ones to keep the forum working properly- it ensures there is room for people to review new Ideas and that the most relevant and meaningful ones can gain votes. We’re archiving this Idea because it's been on the board for well over a year and hasn't received many votes from the community. If you want to raise it again and try to gain more support, you're welcome to do so. We’ve found that pictures and mock-ups can help get concepts across and win more votes from other users. If you have questions or see a connection between this Idea and others, let us know. - Vault product team
Senthil_Kumar
Status changed to: Archived
