Export function for data of selected files
Greetings.
It would be great if "Export" function (File --> Export) would support exporting the data of selected files. Currently it exports data of all currently listed files regardless of select.
Direct copy-paste to Excel would be preferable, but it can have problems with specific characters (for example ";").
Link to problem of direct copy-paste and limited "Export" function:
https://knowledge.autodesk.com/support/vault-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Best regards,
Rene Repina
4 Comments
ihayesjr
@ReneRepinaLedinek
Have you tried selecting the first entry in the History tab and selecting Export?
ReneRepina
Greetings @ihayesjr.
Sorry for the late reply. I did not see the notification. I am replying from this account, since it is the main one (other is from the work).
As for your question, I do not exacly know what you would achieve with this? If I select "History Tab" that just exports all of the current file versions, which is not the result that I want (getting all data from filtered files).
Best regards,
Rene Repina
ihayesjr
@ReneRepina
When you say exporting the "data", does "data represent the file's properties?
ReneRepina
@ihayesjr
That is correct. For example "Title", "Filename", ... This is what Vault "Export" function does, but for all listed files, not selected ones.
